View Single Post
Old 02-11-2024, 09:38 PM
Scratch and dent's Avatar
Scratch and dent Scratch and dent is offline
Scratch and dent is on a distinguished road
Oil change info
Oil type
0w-20
Capacity
6.6 qt with filter
6 qt without filter change
Torque specs
Skid plate bolts 10lbs
Oil filter housing 18.44lbs (I usuallt tighten all the way down, then back it off right before the tab lock)
Filter cap bolt 10lbs
Oil pan drain plug 30lbs
Fumoto drain plug valve
Thread M12 - 1.25
Oil
Penzoil Platinum 0w-20
Prices 2022
Walmart 5qt 23.78
Home Depot 5qt 27.50
Resetting the maintenence reminder
-Key turned to accessory
-Odometer on trip a
-Turn key to off
-Hold odometer button while turning key back to accessory
Filter
Dimentions
Height 3.2
Inside Diameter 1.1
Outside Diameter 2.75
Current filter I use:
Fram
Synthethic
55 Pleats
XG10158
Walmart 14.50$
OEM
Toyota
Cellulose
42 pleats
04152-YZZA5
5$
Purolator
PBL25609
48 Pleats
20$
Toyota TRD
PTR43-00079
25$
Supertech (Walmart special)
MP10158
Cellulose/synthetic mix
56 Pleats
5.49$
Mobile 1
M1C256A
15$
5th gen V2 (Safetymobile)
Scratch and dent is offline   Reply With QuoteReply With Quote
