Originally Posted by 19963.4lsr5
Does your overflow always go back to the same cold level?
Generally three heat cycles with a properly operating rad cap should push all the air out of the system.
Not sure but thanks for that insight, i'll monitor that
I need to try and get the truck mobile so I can get back to my garage so I can figure this out. But my house is 25 miles away up a steep mountain so it'll take all day to limp there.
I want to try running without the thermostat and see if that'll get me home or at least to a shop.
The gasket/o-ring is on the thermostat so will the neck leak if I remove the thermostat?
BTW I got a scan tool so I'll grab some helpful data next time I'm with the car
