Originally Posted by DJRodriguez88
Thanks again, I ended up doing this and it was indeed easy and quick. The most annoying part was draining the coolant and removing my dynamic tensioner (sits right in front of the thermostat housing)
Glad you got the gasket made.
I'm confused about having to remove a dynamic tensioner.
Other than draining the rad I've never has to remove anything else to remove the thermostat housing.
You can check your current thermostat in a pot of boiling water.
