View Single Post
Old 02-16-2024, 02:50 AM
t-rex grrr 2 t-rex grrr 2 is offline
t-rex grrr 2 is on a distinguished road
Help Needed! P0121, P0123, & P2135 Error Codes
SOLVED! - SEE BELOW
Hi all. My 4runner is stuck in limp mode and I can't figure out why.
ISSUE
P0121, P0123, and P2125 error codes show on my scangauge and immediately reappear after I try to clear them. I have a 2006 V8.
BACKSTORY
I changed the spark plugs on my V8, and in order to do so, I had to remove my intake. While it was removed, I decided to clean my throttle body, which I've done before with no issues. I disconnected the electronic clip and the locking clip snapped. I bought a new clip, re-pinned the wires in the correct order, and that was that. I unbolted the throttle body and cleaned it with the coolant hoses still connected. No issues there.
Throttle body was reinstalled, electronic clip plugged back in, and intake reinstalled. I turned on my car and saw the "VSC OFF" and "VSC TRAC" lights on along with the three error codes on my scangauge. I press on my gas pedal and nothing...f*ck
I've never had an issue with my 4runner. It's gassed up and the gas cap is tight. Disconnecting the battery does nothing. I've searched a number of boards regarding this issue, but there doesn't seem to be a specific fix.
PLEASE chime in if you've experienced this and have a solid fix. Thanks!
t-rex grrr 2 is offline   Reply With QuoteReply With Quote
