View Single Post
Old 02-16-2024, 11:22 AM
P_nlsn's Avatar
P_nlsn P_nlsn is offline
Real Name: Parker
P_nlsn has a spectacular aura about P_nlsn has a spectacular aura about
P_nlsn's Avatar
Real Name: Parker
Originally Posted by Farmgirl007 View Post
Bought an 08 limited with a known bad engine. Presently have most of wiring connections, main harness to ecu, rad, fan clutch off. Ready to split transmission from motor. Looking for a sticky or procedure on engine removal. Thanks
I agree with aquasport, there isn't a huge pool of resources out there, and even fewer where it's all compiled into one spot. I didn't do a full write up on the removal, and I have the v6, but maybe my engine swap can give a little insight. Posts #4-5 are the prep and removal. Feel free to reach out with any questions you have, and good luck!
07 Engine Swap into an 03
And here is a semi-complete list of steps I could think of off the top of my head, but don't take it as 100%:
Drain and remove radiator
Disassemble all air intake hoses + fuel lines
Remove fan and fan shroud
Remove serpentine belt
Unbolt starter + bell housing
Unbolt power steering pump
Unbolt ac compressor + lines
Remove starter
Unbolt flywheel
Unbolt + remove exhaust manifolds
Disconnect all plugs and lines (like coolant lines and transmission line brackets)
4wd V6 '03 Sport w/ 340k miles (175k engine swapped @ 326k) // 3" Suspension Lift + 3" Body Lift on 35" K02's
@toto.runner // Build Thread // Engine Swap Write-Up
P_nlsn is offline   Reply With QuoteReply With Quote
