Real Name: Lukas Weber
I'm not a pro on this model, but you might wanna look into a few things that could be causing that noise, like something related to the drivetrain or driveshaft. Check the driveshaft for any imbalances or wear. Sometimes funky noises at certain speeds can be linked to those. Also, the differential gears might need some tweaking. Even a tiny misalignment can make those intermittent noises, especially in specific speed ranges. Make sure your differential fluid levels are good and up to spec too. If the fluid's contaminated or not enough, it could be the culprit for those weird sounds.
