View Single Post
Old 02-23-2024, 10:02 PM
DJRodriguez88 DJRodriguez88 is offline
DJRodriguez88 is on a distinguished road
Originally Posted by 19963.4lsr5 View Post
How old is your rad? How clean is it when you look in the top?
Radiator and cap are ~2 years old. It looks very clean. I've filled and drained my coolant a few times since the head gaskets and it comes out basically the same clean pink color every time
When you say “turn them off” are you turning off the fan and putting the temp lever to cold
Yep!
Originally Posted by phattyduck View Post
Your test is showing there is no (or near no) flow to/from the radiator.
Ok, so that sounds like either my t stat isn't opening, there's a blockage, or the water pump isn't pumping.
The tstat seemed to operate correctly when I boiled it (see video). Also, it was working just fine before the head gasket work, so idk how it would go bad just sitting on the bench. I'll try a new one anyway just to be double triple extra sure.
The water pump is a brand new aisin unit being driven by a new timing belt which is being tensioned by a new tensioner.
As far as a blockage, is there any way to test for that? It stayed cold (~145-155°, max 167° up a long steep climb) without a thermostat so it seems like there isn't a blockage, unless it's only partially blocked and would have actually been even colder.
DJRodriguez88 is offline   Reply With QuoteReply With Quote
