Originally Posted by Kokomodo
First, 2wd to 4wd...respect. That sounds like a lot of work. Second, it seems to be the consensus that due to wear and the need for precise alignment of the bearings to races, pressing them out is preferred. I"m going to give the mechanic (who has a great reputation) the benefit of the doubt and assume there was something wrong (rust?) with the bearing/hub/knuckle. However, this sounds like something I need to learn to do.
Oh! I'm just now figuring out that my previous experience is all on my 2WD F150...which uses rotors with pre-installed races. In the past, I've simply replaced the bearings when I replaced the rotors. With the 4Runner (4WD) the knuckle and hub assembly is completely different, and uses pressed in bearings. Okay. Now I'm tracking.
Also I did non-ADD conversion not ADD like most 3rd gens. So I can't compare bearing not torque specs. But I will tell you non-ADD wheel bearing nut torque spec is absurd at like 220ft/lbs. Our wheel bearings are no joke.
