[QUOTE=crawlingjunk;3830230]Maybe the rack is cold?[emoji16]
It's definitely freezing!
Originally Posted by Boort
I'm assuming that you have already checked that all connectors are tightened to spec and that any washers are installed and in good repair.
Do you have a bug deflector on the hood? if so try taking it off.
Boort
The rack is dead silent at all times except when temperatures drop below freezing. All bolts were installed with washers and loctite. No bug deflector.
Originally Posted by GhostRing
Absolutely get the fairing to make contact with the roof. The lower edge is likely buffeting in the wind since there is no support directly behind it.
Add some 3M/helicopter tape to the roof to protect the paint if it's not there already.
Also, is the fairing cut for a lightbar?
I have that helicopter tape on the roof under the rack. There's no lightbar cutout.
Originally Posted by ThorRides
Closer equals less noise.
Sounds like you guys are indicating the metal may be shrinking in really cold weather just enough to start flexing.
