Originally Posted by jgue467
It probably needs more than just the springs/struts, what I replaced last year and Yes it rides like a Dream as well as off-roads very well:
2 X Front Springs - Blue / Yellow 48131-35400
2 X Front Shocks 48510-39436
2 X Rear Springs - Yellow / Red 48231-35210
2 X Rear shocks 48531-80693
4 X Front Upper Top Control Arm bushings 48632-35080
2 X Front Bottom Control Arm bushings front side 48061-35040
2 X Front Bottom Control Arm bushings rear side 48061-35050
1 x LBJ Right 43330-39585
1 x LBJ Left 43340-39465
8 x LBJ bolts 90119-10933
2x LBJ protector 43346-60011
2 X Upper ball joint 43310-39016
4 X Link Bushing 90948-01003
2X Shock bushing 90389-14048
2X Front shock cushion 90948-01056
2X Front stabilizer bar bushings 48815-35100
4X Rear Stablizer bar Link bushings 48817-30020
2X Rear Stablizer Bar bushings 48815-10090
4X Rear Control Arm bushings 48702-35070
4X Rear Shock bushings 90385-19007
2X Rear Upper Control Arms 48710-35040
2X front stabilizer link 48820AD010
2X rear stabilizer link 4883035020
1 each: Steering tie rods 45046-39335, 45047-39215
nice list
however it looks like you listed the highlander springs to get that 1 inch extra lift from factory, . But for the front they are 48131-35400 blue yellow pass side, ( however you look up in some catalogs it says for both sides)
but
48131-35350 blue purple driver side ( to compensate for the extra weight of driver, battery and fuel tank all on that side.) and is listed only for left side.
