Don't expect a change in your MPG from that weight difference alone, if anything you'll maybe notice a slight difference in acceleration and braking feel. Expect changing to a different tread pattern and size will affect it more.
I'm currently running BFG KO2 285/70/17 in load range C. Before that I was running KO2 load range E in the same size, about 7 lbs or so difference per tire. So same tread design, same size, no noticable change in MPG.
Sent from my Pixel 6 Pro using Tapatalk
