Originally Posted by Mo's TE
Hi Everyone
I'm experience rough engine run when coming to a stop at the lights or while stopped at a light transmission in D, it happened 3 - 4 times over the last 3 months. Idles just fine in P.
It's a 2015 trail edition, with around 180k miles and the last 50k with Magnuson SC installed. Been running great with lots of pull, no issues, maintenance upto date, engine air filter replaced 3000 miles before, NGK spark plugs have 10K miles on them. Oil change every 3500 miles. Fuel is 98 Ron (93).
Scanned for codes there are U0100, U0101 lost communication with Traction Control Module. No misfire codes.
Did anyone experience similar issues? What did you do to resolve them?
Thanks
Be sure to always use Top Tier gas as recommended by Toyota. Top Tier gas has more cleaners in it than other gas, so your fuel injectors and mass air flow sensor stays cleaner.
If after you clean the mass air flow sensor, as others have suggested, you are still running rough, put a bottle of Techron in the gas. Techron is essentially adding more Top Tier gas cleaners, which will help your fuel injectors stay clean.
