Originally Posted by brillo_76
Interesting. I have seen circuits melt down when led bulbs are in use. I can't say I saw what happened to your hatch before. Extremely odd, as you are correct, the fuse should have burned open. Unless the melt was just below the fuse threshold.
I can't imagine a scenario in which a 16ga wire can burn completely through, taking the insulation on several other wires with it, and pull under 20A. Would kinda negate the 20A fuse purpose if so, it would seem.
