CV axles always spin, even in 2WD. There should be *slight* play in the axles, but not much at all (up and down). In and out and in rotation there is play/backlash (a few mm/degrees).
The slip joints in the prop shafts can hydraulic (stop being able to compress) if they are overfilled with grease, that may have been part of your issue.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
