270k 04 v8
bought it with 268k and no tag or service history of it being done. Worked at Toyota/Lexus dealer at the time. Tech said it was original but didn't look bad. Explained the angles for the routing on the 2uz make them less likely to fail compared to other engines. I had a customer there with 346k on 03 v8 with original belt. Engine failure was caused by his daughter letting a radiator leak go without keeping coolant in it.
Eibach pro truck with WOR springs on 1st notch in front. 5100's in rear w/ FJ OEM takeoff coils. 255/70R18 on 18" Limited wheels. 1.5" spacers on rear(one trimmed a bit to correct lean). Gibson catback, 06+Headlamps, auxito 16K bulbs in high, low, and fogs!
