Notices
View Single Post
Old 03-14-2024, 10:47 PM
4x3Lander's Avatar
4x3Lander 4x3Lander is offline
4x3Lander will become famous soon enough 4x3Lander will become famous soon enough
4x3Lander's Avatar
FS: SF Bay Area 2002 3rd Gen Toyota 4Runner 4X4 SR5 Sport Edition - $14,500
Selling a 2002 3rd Gen Toyota 4Runner SR5 Sport Edition. In addition to everything below, I have replaced numerous bad condition bolts, clamps, brackets, etc. I have also tried to remove as much as I could from various areas. Wasn’t bad rust, but needed removing. Still a small bit of rust here and there. Finally, I am not removing any component on the 4Runner to make it cheaper. This is sold as a complete unit, CASH ONLY - $14,500. Here is a long list of details.
Ad I posted on CL so you can see pictures - 2002 toyota 4runner for sale by owner - Gilroy, CA - craigslist
- Purchased on 9.16.18 at 172,425 miles
- Currently has 192,XXX miles
- Salvaged title from a couple of owners ago. See rear hatch door picture showing the damage that caused it to be salvaged
- Garaged entire ownership, except the last 4 months, in which it has been covered (cover included in sale)
- OEM owners manual
- OEM original window sticker
- 2 remotes / 3 keys
- Tags expire March 2025 (just smogged too)
ENGINE
- Spiker Engineering hood struts
- CBI ditch light brackets
- Nilight 4” ditch lights
- Satoshi grill
- Get Lost battery terminals
- PIAA dual sports horns
- Honda Odyssey windshield washer sprayers
- Transmission cooler kit
SUSPENSION
- American Racing AR172 Baja Satin Black Rims + spare
- Nitto Terra Grappler G2 33” Performance Radial Tire-285/70R17 + spare
- Locking lugs on all lugs
- Bilstein 5100 / OME 883 front shocks / springs
- Bilstein 5100 / OME 861 rear shocks / springs
- Tundra big brake upgrade
- Tundra caliper rebuild kit
- Wheelers Offroad brake lines
- Eimkeith panhard correction kit
- Durobump bump stops front and rear
BUMPERS
- Addicted Offroad front bumper
- Badland APEX 12,000 pound winch (never used)
- RCE front skid plate
- 2 Rhino USA shackle / D-rings
- Nilight 20” lightbar
- Windshield washer bottle relocate kit
- Shrockworks rear bumper
- 33” spare tire
- Hi-Lift jack
- 2 5-gallon Wavian NATO Jerry Cans
- Traxack tire bag
ROOF RACK
- Homemade roof rack
- Frontrunner wind fairing
- 38" CO Light LED light bar (white and amber) (not hooked up)
- 3 Sherpa Adapt plates (mini)
- 2 sets of recovery boards (forget the brand)
- Plano gun case with recovery gear (included, see picture)
- 3 2-gallon Roto Pax
- Shovel (axe not included)
INTERIOR
- Center differential lock
- Driver side sunvisor molle (items on molle not included)
- Victory 4X4 center console molle (items on molle not included)
- 6-gang Auxbeam wire management system
- Homemade RAM mounts (removed OEM radio unit) (RAM holders not included)
- WeatherTech driver / passenger / rear passenger floor liners
- Outbound Nevada rear side windows molle (items on molle not included)
- Homemade rear cargo drawer system and sleeping platform
THE “BAD”
- Hole in body under front passenger side door (bought it this way)
- L shaped crack in windshield. Not vision impairing
- Replaced both sides ABS lines with aftermarket; issues with this so unplugged ABS / traction control plug
- Missing driver side Sport Edition badge
- No exhaust pipe - exhaust ends at muffler (bought it this way), but sounds normal (not loud)
- The carpet wasn’t in the greatest shape when I bought it. Some areas feel stiff because the previous owner left the sticky plastic coating on the carpet that dealerships use to keep the carpet clean. After years of use, heat and cold, it was very difficult to get off
- Rear view mirror is missing the cover plate in front of it
SERVICE HISTORY
9.29.18 / 173,066
- replaced brake pads / rotors, front and rear
- replaced brake fluid
- replaced coolant
- replaced fuel filter
- replaced power steering fluid
- replaced transmission fluid, filter and gasket
- oil / filter change
10.13.18 / 173,160
- replaced timing belt
- replaced timing belt tensioner
- replaced timing belt tensioner roller bearing
- replaced idler rolling bearing
- replaced water pump
- replaced thermostat / gasket
- replaced coolant
- replaced camshaft seal
- replaced crankshaft seal
- replaced alternator belt
- replaced a/c belt
- replaced power steering belt
- replaced PCV valve (kit)
- replaced various clamps with OEM clamps
1.21.19 / 175,455
- replaced third brake light housing, screws and bulb (to LED)
- replaced license plate clear covers, screws and bulbs (to LED)
- replaced rear cargo bulb (to LED)
- replaced dome bulb (to LED)
- replaced map lights bulbs (to LED)
- replaced door sill screws for all four doors
- replaced all interior lights with LEDs
2.9.19 / 176,477
- fluid levels checked
- tire pressures checked
3.30.19 / 177,902
- replaced spark plugs
- replaced spark plug wires
- replaced O2 sensors
9.14.19 / 181,733
- replaced bushings / bolts / nuts on rear panhard bar with OEM parts
- replaced upper control arms with OEM parts
- replaced upper control arms bushings / bolts / nuts with OEM parts
- replaced lower control arms bushings / bolts / nuts with OEM parts
- replaced sway bar bushings / bolts with OEM parts
- replaced end links with OEM parts
11.29.19 / 182,092
5.24.20 / 185,583
- welded on Eimkeith panhard correction kit
- replaced headlight LEDs
- snipped wire for daytime running lights
- blacked out front corner marker lights and installed LEDs
- installed Satoshi grill
- replaced battery
- replaced rear taillights and bulbs with LEDs
- replaced blinker relay (due to rear LEDs)
- replaced rear hatch struts
- installed rear springs / shocks
- replaced shocks bolts with OEM
- replaced transmission shifter arm
- replaced center frame crossmember
10.31.20 / 186,202
- replaced rear brake lines with extended brake lines
- replaced rear differential oil
- extended rear differential breather plug
- added new refrigerant to AC pump
2.26.21 / 186,539
- replace intake plenum gaskets (2)
- replaced valve cover gaskets (2)
- replaced valve cover bolt washers (16)
- replaced semicircular plugs (4)
- replaced camshaft plugs (2)
- replaced spark plug tube seals (6)
4.10.21 / 186,733
12.16.21 / 187,131
- replaced both sides front fender well trim pieces
- replaced passenger side coolant line shield
- replaced passenger side airbag relay
- replaced power steering lines
- replaced power steering pressure switch
- replaced rag joint
- replaced front differential seals
- replaced both front axles
- replaced both sides ABS lines (aftermarket; issues with this so unplugged ABS / traction control plug)
- replaced both sides ABS frame brackets
- replaced both sides all brake lines and L joints
- replaced both sides UCAs
- replaced both sides LCAs
- replaced both sides LCA cam assemblies
- replaced both sides bumpstops
- replaced both sides springs / shocks
- replaced both sides spindles
- replaced sway bar
- replaced both sides sway bar end links
- replaced both sides UBJ
- replaced both sides LBJ
- replaced both sides steering rack outer tie rods
- replaced both sides calipers with Tundra big brakes
- replaced both sides rotors
- replaced both sides brake pads
- replaced radiator
- replaced radiator hoses
- installed transmission cooler kit
- replaced air filter
- added cabin filter mod
- replaced hood latch cable
- Les Schwab alignment / brake fluid flush
- rotated tires (not spare)
- replaced all bushings on everything above
- cleaned power steering pump screen
- performed washer bottle relocation mod
2.19.22 / 187,667
- replaced battery terminals
- installed battery tray
- installed center console molle
- installed 6-gang Auxbeam wire management system
3.3.22 / 187,806
- replaced thermostat o-ring
- replaced transmission crossmember
- replaced fuel filter tube main
- replaced fuel filter tube main rear
- replaced fuel filter bracket nuts
- replaced air filter box
8.24.23 / 189,651
1.25.24 / 191,008
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
4x3Lander is offline   Reply With QuoteReply With Quote
