Originally Posted by alia176
syn oil are more "slippy" than conventional oil but I'm surprised why the leak is still present after replacing the seals with OEM seals. Wonder if something else is going on?
Well it’s either the breather or companion flange sealing surface is really worn. When I did the seal I noticed the breather hose was rotted off the transfer case actuator. I trimmed it and stuck it back on. It might have been to tight and pinched. Maybe pressurizing the transfer case? I bought a stainless 1/8” barbed union and 1/8” ID fuel line and made an extension tonight. We will see if that helps first. Otherwise new companion flange and new seals all over will be $200. I tried to blow through the breather tube. Felt like it kept taking air but when I let off it push out some nasty gear oil gas. Yuck That might be normal if the breather has inherent flow restriction?
