Originally Posted by 4skrunner
Also I did receive the hardware already. Came in a 13 lb box with double the required brackets and a bag with like 100 nuts and bolts. Pretty sure the bracket kit has extra pieces for other vehicle fitment but kind of seems like a waste on their end. I don’t mind the extra pieces though….
It does take quite a few bolts to mount the bracket to the basket, but you're probably right some sort of universal fit kit.
ARB manufactures in China as does IronMan, maybe they let the licensing run out or it's enough different they can avoid a suit.
