All dobinson rear springs are at least 20% stiffer than stock (180lb/in stock vs 220lb/in minimum from dobinson). This will make your ride a bit harsher, but will improve handling. However in terms of aftermarket springs their spring rate is already on the low side, OME's springs are 260lb/in minimum. I believe only Bilstein, wheeler, eibach makes springs with close to stock spring rates, but they usually provide more lift. So there's not many options for slight lift springs with similar spring rate. You might actually want to look for spacers or FJ cruiser springs.
