Two quick notes:
- The engine will not run without a sealed tube between the MAF sensor and the throttle body
- The fuel pump does not prime/run with the key in the "ON" position. It will only run while the key is in the START position or the engine is running.
If you are trying to do starting fluid, you need to pull the tube, spray, then reinstall the tube... Or spray it in a vent line or something like that.
In general, "turning over" is the term used for the starting moving the engine, not when the engine is running.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
