Originally Posted by toverturf
How are these LC 7.5 springs working out for you? I used to have the 210V springs on mine but switched to OME 890 springs because 210V was too high for the weight I had at the time. Now I have more weight but still not sure if the 210V springs will be too high. Maybe I just need to buy a few different springs and try them all out first haha.
I like them a lot, they settled perfectly and ride just the same if not a tad better than the 210v coils. Right now I have maybe half an inch of rake and it looks miles better than the 1.5-2in before. They're also much easier to compress and install/remove since the coil is slightly thinner, it was always a total pain to get the compressors in them and squish them down enough to pop them out
If you're one of the people who has a half inch lean in the rear then it would be smart to use one 8 wrap and one 7.5 wrap to even it out (about a 0.4 inch difference between the two), but for some reason I only have a 1/4 inch lean so I just use trim packers and it worked out perfectly
It would also be smart to get a close ballpark of how much weight you're carrying in the rear. I'm probably around 260lbs: my bumper is 150lbs, plus a 65lb spare tire/wheel, 25lb hi-lift and a small amount of tools and recovery equipment. Tbh I try not to think about all my extra weight and how much it's probably slowing me down lol but if I had to give an estimate for reference it's probably around there
Y2K Highlander
Millennium Silver 3.4L auto @ 320k and climbing
