Originally Posted by Apogeo
If not JBL amplified system it is a 1" tweeter. I think this is the one you want, may be able to get it locally in Canada... fellow Canadian here, relocated to the States 5 years ago.
You could also use this opportunity to swap for a better set of tweeters and better 6x9s in the door. If you search here a lot of people have great results from this swap. Go for a 6x9 component set and it is pretty close to plug and play.
You will need a wiring harness like this, or Crutchfield will include the Metra ones with your purchase (or charge you $10 at most). You will need to install (solder) base blockers, or farm this out to someone. If you have a friend that can do this it takes 30 seconds.
You will also likely need speaker mounts. These are from Metra, I went a bit higher end since I opted for high end speakers and wanted to avoid flex etc. The Metra ones are likely close to stock quality.
The hardest part will be removing and reinstalling the door panel.
Stupid question here, but are all 1 inch tweeters same fitment? Could I say just get a basic tweeter 1 inch of crutchfield or whever and have it fit? I take I dont need wiring harness or solder for the tweeter or do I?
Thanks for the help on this. I am not very good at speakers and audio..but the ripping sound from the left front..has to go!!!
