View Single Post
Old 03-31-2024, 02:30 PM
SurferUK's Avatar
SurferUK SurferUK is offline
SurferUK has a spectacular aura about SurferUK has a spectacular aura about SurferUK has a spectacular aura about
SurferUK's Avatar
Originally Posted by chisel View Post
Hello everyone,
I think I've read every post here wrt performing the ATF exchange. Doing it today on a (new to me and first 4th gen.) 2008 Limited 4x4 V6. Due to a leaking X-REAS and sloped floor, how do I know when the vehicle is level to check the ATF fluid level? The FSM shows the top of the oil pan level, but I'd have to jack up the back end of the vehicle quite a bit to get to that point. That can't be right. With the factory running boards level and the frame the same or close, then the bottom of the pan is not level and neither is the top, not by a long shot.
What's the solution? Get the frame level and check the ATF fluid in that position?
They designed it to cope with steep gradients etc...I'm sure there's enough of a designed in "over fill" that you don't need the truck level to the millimetre. My last one wasn't, I think I just put a spirit level on the running boards and across the rear bumper, and the gearbox was fine afterwards, right up until I stuffed it into the Armco.
I spent more time making sure I got the temperature right for the level check procedure etc etc than I did getting it spot on level.
My new one has the previous transmission, with (Thankfully) this thing called a dipstick. Maybe they will catch on?
2008 2.7 2WD 4 speed (Tacoma-Runner?)
SurferUK is offline   Reply With QuoteReply With Quote
