Real Name: Skip
Real Name: Skip
I don't know if all of your issues would be solved...but it should eliminate any issues with the master cylinder assembly as long as it's installed and bleed correctly, unfortunately the ABS system not only relies on the master cylinder assembly but also input from the speed sensors as well.
At this point I would check for ABS codes, the reader you posted above should work for that and then proceed from there.
2004 Limited V8
