Originally Posted by teotwaki
Looking forward to the pictures!
If the cooler is moved behind the bracket the lower inlet tube and attached hose will have to contend with the radiator mount being squarely in the way. I think the bracket would be mounted first then try to get the cooler in there to rotate into different positions for fitment check. The bracket that you now have is the result of three different designs iterations.
Your picture of this is what caused me to ask if the transmission cooler could be mounted to the other side. That bottom barb looks like it would have to contend with the radiator mounting bolt, but I couldn't tell for sure.
