If its just coming from the front output, there is no need to pull the case. Just remove the front drive line, remove the flange, pull the old seal, replace...
Probably a good idea to drain the case before pulling the seal.
I had to do the rear output on mine years ago, removing the flange bolt was probably the hardest part.
SAS 97 4runner / Bone stock 2005 4runner / aka "Kurtfab"
