VSC TRACK VSC OFF ABS Lights on, ZPC didn't work
The VSC TRACK, VSC OFF, and ABS lights are intermittently coming off and on.
I did a Zero Point Callibration earlier today, and the ABS light went off for a few minutes, then came back after a quick test drive.
I remember there was a TSB or similar years ago that you can get ABS codes by jumping the OBD connector with paper clips. I even posted about it and got a code (RT Front Wheel Speed Sensor)
I cannot find that document, even though mulitple threads speak of it. So can someone lead me to it?
Or can someone give me an OBD scanner that will currently pull abs codes out of a 2004 Sport 4x4 V6, please?
My memory is pre 2006 models don't play well with some scanners, so the paperclip method is preferred. I have a bunch of DTCs from Techstream, but I am unsure if I did the code retrieval correctly.
I also am unsure as to the timeframe of those codes:
Under Signal Check (UT-04-004)
CURRENT DTC: 14
C0371
C1271
C1272
C1273
C1274
C1275
C1276
C1277
C1281
C1282
C1278
C1281
C1282
C1283
C1336
C1379
Also the explanations for each code were there, but there are too many to list.
If these are current DTCs, that many is pretty substantial.
So can anyone help with digesting and diagnosing this issue please?
Thanks for any help!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
