Real Name: Patrick
Real Name: Patrick
When you doing the bleeding, did you do the rear brakes? You don't mention the rear set of brakes at all.
Did you bleed the LSPV last of all? They're known for collecting dirt/crud, and air.
Just checking. After all, the rear brakes are bled first, and the LSPV last. Any of them can have air in them, after all. Heck, for all I know, you may have a rear axle seal leak, and the the rear shoes need replacing. I had that, and once I got them replaced (I hate drum brakes!) it was night and day. The pedal firmed up, and the whole brake system felt like a new one.
Anywho, good luck to you!
Pat☺
