The kit arrived yesterday. I ordered the Iconic mount with the Hayden 698 cooler. I am prepping the kit for an install this weekend. I added a push nut bolt retainer to hold the spacer, though it isn't needed (just makes things a little easier). I also added a washer to use between the nut and mounting point, also not really needed.
I have a couple questions though.
Where does the edge trim guard that came with the kit go?
How did others add the extra transmission fluid to the system? Did you fill the external transmission cooler when connecting the hoses, or did you top the system off with a quart of oil while it was running?
Reason: Grammatical Error
