View Single Post
Old 04-16-2024, 02:55 AM
ChildrenOfBodom's Avatar
ChildrenOfBodom ChildrenOfBodom is offline
Moderator
Real Name: James
ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light ChildrenOfBodom is a glorious beacon of light
Moderator
Real Name: James
Did you receive those weather seals? How'd they look?
I have an 87 turbo. Some years ago, it had an issue where startups took too many cranks and the cold idle was low and often stumbled enough to stall.
After a test using a voltmeter, it was apparent that the cold start injector thermo time switch (left side threaded sensor under intake) was out of spec.
I bought a Beck Arnley unit from RockAuto which luckily turned out to be a repackaged OEM part. The truck starts up instantly and idles up great.
Perhaps a quick check on that sensor could net some answers.
The poof of smoke on startup is characteristic of failed valve stem seals. Is it blue smoke?
IG: @jimharb | YouTube
'99 4Runner - 2.7L 3RZ-FE - TRD S/C - 4WD Conversion + R150F 5-Speed Swap - Imperial Jade Mica on Oak
'87 4Runner Turbo - 2.4L 22R-TE - CT-26 Supra Turbo - W56 5-Speed Swap - Red on Red
'90 4Runner 2-Door - 3.0L 3VZ-E - Auto to R150F 5-Speed Swap - Red on Gray
'94 Supra Turbo Targa - 3.0L 2JZ-GTE - Marlin Crawler R154 - Imperial Jade Mica on Black
'89 Supra Turbo Targa - 3.0L 7M-GTE - Marlin Crawler R154 - White Package on Blue
'89 Pickup DLX 2WD - 2.4L 22R-E - W55 5-Speed - White on Blue
ChildrenOfBodom is offline   Reply With QuoteReply With Quote
