Originally Posted by razor_ro
I was hoping someone can help me, I’m contemplating to get a leveling lift kit…not sure if it would help tho?
I have a stock 2016 limited (7 seater), I did recently put Falken WildPeak A/T3’s 275/60/20 … I did remove the back mud flaps and in the front, I used a heat gun to bend the plastic in … all is good, however, only when I reverse and turn I hear rubbing in the front… the rear rubs sometimes (also … I think)…
Looking at a side profile, the front spacing/gap between the wheel and the wheel well seems like 1-2” smaller than the rear
If I put in 2” lift in the front and a 1” lift in the back, would this help with the rubbing I’m experiencing?
Also, are there any other things I have to consider with doing this? Will I need new shocks or anything else?
Check the OG fitment guide linked below for more info. You are in the red zone with 275/60/20 so likely need heavy modifications to clear your BMC and fenders.
Going Bigger - 5th Gen Tire Fitment Guide
