Real Name: Jerod
Real Name: Jerod
Mine looked like that at 190K miles when I bought it, leaking valve cover gaskets. You can try the UV dye kits on Amazon or other places where you place the dye in your oil, drive it around as usual for a few hundred miles and then check out the engine with a blacklight. The leak will glow under the UV light and tell you exactly where the leak is. My money's on the valve cover gaskets.
Just think of it this way, the bottom of your engine now will never rust!
