View Single Post
Old 04-18-2024, 12:39 PM
Buckaroo's Avatar
Buckaroo Buckaroo is offline
Buckaroo will become famous soon enough
Buckaroo's Avatar
I did get it up with the jack stands under the lower control arms and ran it in 2wd, 4wdh and 4wdl at probably 10mph. Checked each of the wheel bearings (front & back) with my stethoscope but did not hear anything. I had already done all the classic wheel bearing tests without finding an issue and had replaced the CV axle on the left side because the outboard boot was split but no joy - noise continued. So I bit the bullet and bought the Steelman Pro Chassis Ear2 - $140 from Amazon (the wired one - the wireless version is $300 and the wired version works great). Hooked it up to the front right & left wheel bearings, front diff and transfer case. Could tell right away that the right wheel bearing was an issue. I guess it had not gotten bad enough to make noise except under load. I try to limit money spent on specialty tools but when you need it, you need it. Ordered the SKF Wheel Bearing Assembly BR930978 from Rockauto.
2000 T4R SR5 V6 (Retired) & 2005 T4R Limited V6
2002 & 2017 XLE Camry
2004 Honda Accord
2017 Tundra Limited DC 5.7L TRD 4WD
2024 Honda Pioneer 700-2 Deluxe
Buckaroo is offline   Reply With QuoteReply With Quote
