I feel your pain. I didn't think I was going to do a rear bumper either till I moved to tires that wouldn't fit underneath anymore. And I was dragging my spare and the rear bumper cover. (I ran an undersized spare for awhile, if you don't flat much you could consider stuffing a skinny 34" tire underneath.)
Now that I've had it 5 years I love it and couldn't imagine not having it. Much better storage for propane, fuel, water, hi-lift, traction boards, trash etc. And honestly dragging a 90# spare from underneath and shoving the flat one back under in off road conditions sucks.
I can't even imagine the nightmare of having my spare on my roof.
Originally Posted by TRDHULK
That is a solution, but that is not what I want to do. Not the look I'm going for with my 4Runner.
I do like the Nguyen Works high clearance rear bumper, but I use my hitch way too often to live without one. The OEM hitch crossmember shows way too much with the high clearance bumper and looks like booty. Plus this requires cutting up the rear bumper which I am trying to avoid for now.
