Originally Posted by Jeremy107
Is there is configuration for my current front end to get my lift? Since I’m doing new LCA and Freedom off-road UCA. And just swap the rears to 895 for more lift?
It’s been a few years since I did the 5100s and FJ coils up front so can’t remember exactly what I set the 5100s to. (EDIT: I set them to 1.75) I’ll check. It’s got 260k on it so good idea on tie rod ends while in there. New sway end links complete already
your ome are lift springs, leave the 5100 set at the lowest, it'll probably give the same results as your current front settings, just firmer and your not preloading them.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
