Originally Posted by riceandpho
your ome are lift springs, leave the 5100 set at the lowest, it'll probably give the same results as your current front settings, just firmer and your not preloading them.
I currently have the FJ coils on all 4 corners with 5100s set on 1.75 in the front.
Wanting to upgrade coils in the rear as with the roof top tent during our trips the FJ coils sag to bad. If I upgrade to OME 885 it will result in more lift in the rear than current set up and better spring rate from what I’ve read. Can I adjust the front 5100s with the FJ coils anymore? Or better off to upgrade to 895s?
The OME coils 885/895 and 5100 set on 0 is a higher lift than my current set up by 1” or so? Does that sound right?
