Originally Posted by CoCoCo4Runner
Is there anything I can get now, that I can grow into without being horribly compromised in-between? 906/5100 seems like a combo that will work well with my existing stock front end, but will it work long term? I am also not against incorporating something like an Airlift 1000 system.
Thanks!
The 5100's are designed for the 906 springs (read between the lines on the install sheet - the spring description matches the 906's). You'll probably want to do the front 5100's and put the front up one or two notches from stock height, otherwise you will have a LOT of rake with stock height up front.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
