Originally Posted by DJRodriguez88
Might be a silly question but can I remove the front driveshaft on my 4x4 and drive safely without something falling out? I know some cars the diff's input shaft or the transfer case's output shaft is only held in by the driveshaft.
The truck has a spartan locker in the front and wasn't meant to be street driven much but now i need to drive it a lot more
The CVs are required to be in place to drive (they pre-load the front wheel bearings). The prop shaft from the transfer case to the front diff can be removed - but it won't change anything with the front diff - the axles are still there and spinning. The ADD system just disconnects the right front CV from the diff.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
