Only a few reasons why this would be off, bent axle, bent frame or bent control arms. The control arms would be the easiest to accidentally bend and also easiest/cheapest to replace. The tube on both arms should be straight.
Has this vehicle been in an accident? From another post you're in, it looks like the answer is yes. You may want to measure the frame diagonally at a few fixed points.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
