Real Name: Lukas Weber
I’d suggest checking your brakes and tires regularly. Proper rotation and alignment can make them last longer and work better.
Remember to change important fluids like transmission, differential, and power steering.
Also, periodic coolant flushes and checks of hoses, radiator, and water pump can help avoid any overheating issues and expensive fixes.
Inspect the condition of drive belts, including the serpentine belt, and replace them if they look worn or cracked. A busted belt can mess with things like the alternator or air conditioning.
And check your battery and its terminals regularly.
