View Single Post
Old 06-06-2024, 07:36 PM
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Originally Posted by jreask View Post
This engine was really hard to rotate even with the old belt on. The LH cam was hard to move back. Just concerned that it’s ok to start.
Hard to turn because your turning against valve spring pressure and That's why it jumped, one cam lobe right near it's peak open and it tends to spring back. If you rotate the engine by hand through a few complete revolutions now that you have the timing belt on and are comfortable all marks are lined up you should be good. My Highlander did the same thing, and I did the same as you, and when I went to start it, it started immediately and ran perfect.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
