V6 leaking coolant
Trying to track down a coolant leak on my 2006 v6... There's some white smoke when I first start the engine, only when it's cold (the engine, not the weather), and I'm also seeing some coolant below the throttle body and around the water pump. I don't see any water in the oil (just did an oil change). Since there's white smoke I don't think it's the water pump... What are the chances it could be the throttle body? I know it has coolant lines going through it, could it leak a little bit into the intake, causing the smoke? Really hope it's not the head gasket.
