Originally Posted by message
Maybe I'm the only one doing this, but I thought it was common knowledge?
You can flush the PS fluid by simply jacking the front tires off the ground, removing the PS return line, and turning the wheel clock to clock with the engine off and the key in the on position.
To prevent a mess I plug the return port on the reservoir and extend the return line into a bucket on the floor. As soon as the reservoir is almost empty and before it can suck air, I fill it to the top with new fluid.
Repeat the process a few times until the fluid running out is clear.
No turkey basters, no partial fill, and easy clean exchange of all PS fluid.
I did the same method in 2011 on my 3rd gen. Check my photos. Works like a charm.
