Originally Posted by AuSeeker
What you're describing sounds more like the driveshaft clunk, grease the slip yoke until it starts to move from the new grease.
NO, don't just add transmission fluid to a cold transmission and drive it that way, i. e. possibly overfilling the transmission fluid, but it is fine to do as long as you follow up by going through the proper "check fluid level procedure"/getting it up to the correct temperature and then pull the check level plug so you get the level as close as correct as possible, overfilling the transmission can be almost as bad as having the level too low, both can damage your transmission!!
It is on this week's to-do list, for sure! I've been meaning to get to it, have both grease types on hand, ready to go
