12-07-2014, 03:36 PM
#151
Originally Posted by sharpe97
Thanks! And yes, it"s all 3/4 EMT. My dad is an electrician by trade for 15+ years, and I've helped him on jobs for about 6, and this past summer I got a job with him so we used the tools of the trade. We bent all of it. Took about five 10 ft sticks. The loops are held together by 2 set screw couplings for both the upper and lower sections, that are spaced out by some aluminum angle that i had laying around after a job, with more 3/4 EMT for the cross braces. All pop-riveted together, hence the no welds. It does it's job, it's super light weight, but it's still strong enough for my needs.
Thats cool. Im curious how you attached it to the roof rails, just bolts thru the rails? Or did you make some feet to bolt down? I really like how low profile it is.
12-07-2014, 03:55 PM
#152
Made a set of rock sliders
12-07-2014, 04:18 PM
#153
Real Name: Jason
Real Name: Jason
Those look great!
I'm planning on building me some rock sliders soon.
2001 4runner SR5 v6 4x4
TBU | Toytec / Eibach 3" springs up front and Superflex rear | Bilstein 5100 front and rear
Toyo Open Country MT 305/70/16
Specialized Rockhopper Pro 29er
12-07-2014, 04:22 PM
#154
Real Name: Jason
Real Name: Jason
Homemade....Let's see what you've made
12-07-2014, 05:37 PM
#155
Real Name: Dan
Real Name: Dan
Bed Rack for my dad's Tacoma
Front Bumper
After paint and lights mounted
Switch panel
Full length roof rack with light bar bracket and backup light
12-07-2014, 06:15 PM
#156
I was really stumped at first on how, because I couldn't figure out a way, but I ended up using a 3/4 minerallac strap, with a bolt going into the original bolt holes for the cross members. So I can take 6 bolts out and pick it straight up and off the roof.
99 Limited, E-Locker, 4.30's, automatic, C-144 alternator upgrade, sunroof, blacked tail lights, plasti-dipped flares/cladding, Bilstein 5100s and Ebaich coils up front, LC 8 wraps and Skyjacker Nitro 8000s in the rear, custom roof rack, custom bumper in the works...
12-07-2014, 06:48 PM
#157
Real Name: Matt
Real Name: Matt
Originally Posted by dtc81
Switch panel
Love this! Would like some more information on it. I've been looking to make something just like it. Are you running ignition through the red switch?
12-07-2014, 07:36 PM
#158
Real Name: John
Real Name: John
Front Bumper
Switch panel
Got any other pics of that roof rack? It looks really good.
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
12-07-2014, 07:43 PM
#159
Real Name: Dan
Real Name: Dan
Thank! I started with a paper template and fit it to how I wanted. Its just a piece of 1/16" (if I remember correctly) steel, that I bent in the bench vise and made to be bolted to the side supports of my single DIN radio. It fits behind the console trim nicely. I cut out the blanks based on the OTRATTW switches I bought.
Here's a better picture for an idea.
The red switch is actually for 2WD low range. It's just an interrupter. I added how I did it to a 2wd low thread that's floating around here. Other guys have had success with it too.
12-07-2014, 07:49 PM
#160
Real Name: Dan
Real Name: Dan
Thanks! I have a couple kind of crappy shots, hopefully it give you an idea what I did.
Started by building the frame out of Uni-Strut. (Don't mind the dog)
Getting painted.
Different angle.
12-07-2014, 08:48 PM
#161
Originally Posted by Bretski1
I'll join. I'm (almost) a dentist, so I work in millimeters. Trying to cut down on pocket bulk between keys, knife, phone, wallet, and usually a tactical light.
This is so badass, want to see/ hear more.
12-07-2014, 09:54 PM
#163
Real Name: John
Real Name: John
Ack!! Double post. Sorry. Bandit you build some of the coolest stuff. Gotta say it's always fun to watch what you will come up with next.
12-07-2014, 09:57 PM
#164
Real Name: John
Real Name: John
Getting painted.
Different angle.
I really like the low profile and simplicity. Haven't seen the uni - strut before. How's the strength?
I have a design and hopefully it gets built soon lol but I am going for low profile and full length as well.
12-07-2014, 11:13 PM
#165
Real Name: Dan
Real Name: Dan
The uni-strut is very strong. I've had the rack loaded with probably 150 lbs of gear, plus myself standing on it to strap everything down. No issues. The cross members are 3/4" square tube and are notched into the uni-strut and welded. I chose not to run the expanded metal mesh the full length because the front of the rack sits on two 2.5" diameter rubber feet directly on the roof. There is no roof deformity, and I used stainless hardware throughout. I will say though, the uni-strut was a complete pain in the neck to spray inside because of the "C" channel design. I plan on taking it off, sandblasting, and having it powder coated in the spring.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
