12-08-2014, 12:14 PM
#166
Real Name: John
Real Name: John
Originally Posted by dtc81
The uni-strut is very strong. I've had the rack loaded with probably 150 lbs of gear, plus myself standing on it to strap everything down. No issues. The cross members are 3/4" square tube and are notched into the uni-strut and welded. I chose not to run the expanded metal mesh the full length because the front of the rack sits on two 2.5" diameter rubber feet directly on the roof. There is no roof deformity, and I used stainless hardware throughout. I will say though, the uni-strut was a complete pain in the neck to spray inside because of the "C" channel design. I plan on taking it off, sandblasting, and having it powder coated in the spring.
Cool thanks for the info! I think I might have gone a little overboard on the frame then. Here's what I cooked up so far.
98 Toyota 4runner 3rz 5spd 4x4 - Sold Build Thread
06 4runner 2uz Build Build Thread
Instagram: @Kryptowerkz
12-08-2014, 05:03 PM
#167
questions about husband's 4runner
My husband has done so many upgrades to his 2000 4runner including: mud tires, suspension lift, front grill, sidebars, and a few other things I can't think of right now. He wants to build a front bumper and I want to get him the metal to build it for xmas. I need to know how much metal and what kind. I've done a little research on metals and it looks like either steel or aluminum. Any info would be much appreciated! Thanks!
12-08-2014, 05:25 PM
#168
Thats fantastic!
So i just made my own recently, I used a 4x4' sheet of A36 steel, it was 3/16" thick. The cost should be somewhere around 100-120 if you pick it up from a steel yard, so do some research and find some yards in your area. Btw i just barely fit 2 4x4' in the back of my 4runner.
Another thing thats really helpful is getting about 15 foamcore sheets from the dollar store, they are 3/16" thick and easy to cut, which makes them great for making mock ups. Also he needs to have at least a 140amp mig welder, an angle grinder with cut off wheels, a grinding wheel, and an 80 grit flap disk. If he can make a computer model that makes it even easier if he decides to get it water jetted or something.
If you have more questions feel free to ask.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
12-08-2014, 06:40 PM
#169
Real Name: Raul
Real Name: Raul
Originally Posted by sharpe97
I was really stumped at first on how, because I couldn't figure out a way, but I ended up using a 3/4 minerallac strap, with a bolt going into the original bolt holes for the cross members. So I can take 6 bolts out and pick it straight up and off the roof.
That was a super idea. If I had tools (bending/riveting) I would steal this idea.
Cypress, Texas
12-08-2014, 07:01 PM
#170
I just used a 3/4 EMT hand conduit bender for it, and a hand held pop-rivet gun that I got at Lowes/Home-Depot. You could probably get both at Harbor Freight for super cheap and they would work fine. Bending takes some time to get used to and learn, but with some extra pieces and some practice, you could easily do it. There's plenty of videos out there to watch too. I would go for it if you're wanting to do it cheap and don't have the skills or means to weld!
99 Limited, E-Locker, 4.30's, automatic, C-144 alternator upgrade, sunroof, blacked tail lights, plasti-dipped flares/cladding, Bilstein 5100s and Ebaich coils up front, LC 8 wraps and Skyjacker Nitro 8000s in the rear, custom roof rack, custom bumper in the works...
12-08-2014, 07:07 PM
#171
Real Name: Dan
Real Name: Dan
[QUOTE=Kryptoroxx;1864078]Cool thanks for the info! I think I might have gone a little overboard on the frame then. Here's what I cooked up so far.
That looks awesome! Are your mounting feet going to hook into the channel like Thule/Yakima feet, or did you plan on utilizing the stock rails? What are your plans to support the front of the rack against the roof?
12-08-2014, 08:09 PM
#172
Real Name: John
Real Name: John
So far the plan is to hard mount the entire thing to the stock mounting holes for the rails with a solid rubber isolator (1/8 or so) and then for the front feet I hope to use 3m double sided tape to keep them from rattling or bouncing. After that I am just going to adjust the design as it needs to.
12-08-2014, 08:18 PM
#173
12-08-2014, 08:38 PM
#174
xcmtb83, those headrest mounts are great!!! I have a '99, but somehow missed out on the addition that Toyota added to the second half of the generation to hold them to the back of the second row seats. Can you show how you made them? Also, have you tried painting the metal posts to match the leather?
The Renewal of Gaia 1999 4Runner SR5 Highlander IJM
FJ Wheels | Goodyear Wrangler Fortitude HT | TBU
Rancho Shocks & Struts | OME 880 Front | OME 906 Rear | ES Polyurethane Sway Bar Bushings Front/Rear | ES Polyurethane Steering Rack Bushings
Clear Headlight Corners | '98 Rear License Plate Frame & Emblem Delete | Stubby Antenna | Trans Cooler Bypass
12-09-2014, 02:05 AM
#175
Thanks. I made them on an old turd just like the one below. Columbus brought over the one I used to use. I shouldn't complain though I don't even have access to a CNC anymore, just manual stuff here in the toolroom. Making those brackets on a manual mill would just be annoying, wouldn't look as nice and would take too long to make any money on them.
Paint would never stick to the shafts nor would it slide in and out very easy.
12-16-2014, 03:08 PM
#176
This is a great thread and the pictures are incredible. I'm gonna attempt to build a rear cargo box to organize all my fishing equipment once and for all. I'm pretty good at working in wood and for me that's the best option. In some of those pictures some of the wooden boxes were covered in what looks like grey carpeting. I think it looks pretty good and was wondering where can I get some. Is it some type of marine carpet or something else. How did you put it on, glue staples other. I wish I could build the other stuff, but outta my league. Thanks again
12-16-2014, 07:46 PM
#177
Lowes or home depot for carpet. Just regular short pile (or whatever it is called). It's cheap. I used carpet glue and staples easy to do.
2002 T4R Limited, 191K miles - OME 883 front - LC 7 wrap/2nd gen sway bar links rear - Detroit Truetrac Diff - Cooper A/T3s - Warn M8000 - ARB Bumper - homemade (er, 'custom') rear bumper w/tire & can carrier - BajaRack - Diff Breather Mod - Hayden trans cooler - Yaesu 2M, Cobra CB - Fridge, off-road trailer with Tepui RTT (real expo poser)In Africa they say: "Buy a Land Rover and it will take you anywhere. Buy a Toyota and it will take you there ... and bring you back home." jannikt on wranglerforum.com - I'm guessing he didn't make many friends there with that line.
04-16-2015, 11:40 PM
#178
Figured I'd bump this thread because it's one of my favorites....
Made these recently...
And this is almost done being made...
04-16-2015, 11:45 PM
#179
Rack
2020 TRD Off-Road Premium
ShrockWorks sliders
Southern Style Offroad slimline hybrid front bumper
OpenRoad4WD 13000lb winch
Gobi Roof rack and ladder
04-17-2015, 12:14 AM
#180
Real Name: John
Real Name: John
Finished that roof rack
Working on some tow shackle mounts now. Should have them done. Then after that the two next builds will be disc brake mounts and a compressor mount. That should keep me busy for most of the summer lol.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
