06-21-2016, 01:10 PM
#61
Then thats what I will do. The first seal made it to 191K. I can't imagine that I will see 400k miles with her, but who knows. Thanks for the response!
[I]1999 Limited w/rear locker, OME Springs Bilstein shocks, black TRD FJ wheels, Ryno skid, satoshi grill, Hilux snorkel, HID retro-fit headlights, Coastal off-road front bumper, Smittybilt 9500 winch, Shrockworks sliders
06-21-2016, 01:42 PM
#62
That was my thought too. It definitely gave me pause when I was doing it since stripping that thread would be bad news, but it didn't even look stressed at all when I examined the threads after taking the nut off.
Cheers!
2004 Sport Edition V8. 3" OME lift. 5th Gen Brakes. 285/70 Duratracs. JBA UCAs. SCS Ray10s. DT Headers.
1997 4-Runner Limited w/ factory locker. Totaled in February 2018. Still miss it.
06-27-2016, 06:23 PM
#63
Advice for people without air tools: I drilled the divot out of the nut with a titanium bit. Then my 18v impact wrench took the nut off no problem. The drill bit didn't do any damage to the surrounding threads.
Cheers!
06-27-2016, 06:49 PM
#64
That is what I call a very well made DIY, and with all the added info's on the thread, wow. Keeping as future reference.
1998 4runner SR5
06-28-2016, 11:12 AM
#65
Yeah, honestly, I've been discovering most threads are like that here. I've been on a ton of other forums throughout the decade(s), and T4R really takes the cake with the quality of write-ups, the actual reproducible and verifiable info that's given, and just overall willingness to help each other out.
So...we rule!
/rant
09-01-2016, 06:38 PM
#66
Real Name: Alex
Real Name: Alex
Just used this thread to address my leaking front output shaft. Went very well! After tax I paid $17.03 for the nut and seal at my local dealer.
As some others did, I used a 1/2" impact wrench to break the 30mm nut loose. I could not see ANY damage to the threads whatsoever and had no issues torquing the new nut down.
Mine must have been leaking for quite some time as I was unable to remove anywhere near a quart of oil from the t-case. Took almost exactly 1.1 quarts to fill it back up.
Thanks a ton,
@ BigFishAllDay
2006 Lexus GX 470 Sport- RR Diff Lock, Metal Tech Sliders, RCI Aluminum Skids, Front Runner Slimline II Rack, SCS F5s, 255/80R17 ST Maxx , OME BP-51s, Dirt King UCAs, Metal Tech RR Lower Links
2016 Lexus IS300 F Sport- F-Sport Air Filter RR Racing tuner
09-05-2016, 06:48 PM
#67
SO I was able to do this today with our day off.
The instructions were perfect to a T. Even with someone who does not have much experience past oil changes this was pretty easy. Big thanks to BigFish.
Being in the northeast, I had a bit of rust on the underside. I was not able to get the zerk fitting cap off for the grease part of the install. I was able to just push the driveshaft about an inch in and rest it on the 3rd member. When i reinstalled i just hooked it back up.
Think its a big deal? Should i be looking for a new(er) front driveshaft that is not so rusted? I am assuming it has not been greased in years.
4high and 4low work great.
'16 Tundra TRD PRO - Quicksand
'99 4Runner SR5 4x4 - Imperial Jade Mica (gone)
'99 4Runner Limited 4x4 - Millennium Silver Metallic
10-22-2016, 01:49 AM
#68
I replaced this seal 3 yrs ago and it started leaking again. Just like last time, I'm using the OEM seal. Upon closer inspection, it seems that the oil seal lip has slightly worn into the companion flange sealing surface and therefore the surface might be chewing up these seals.
I'm going to see how long this last, and if it leaks again in the near future I'll probably put an SKF Speedi-Sleeve on it to get a clean sealing surface. For future reference, the companion flange sealing shaft is 41 mm OD, so an SKF Speedi-Sleeve 99163 can be used.
10-22-2016, 03:32 PM
#69
thank you for this!
02-02-2017, 01:15 AM
#70
I'm trying to do the rear seal and have two questions:
- Where is the zerk fitting to collapse the drive shaft?
- Tips on how to push the drive shaft away from the companion flange? Mine seemed like it was pretty well stuck together.
07-30-2017, 11:50 PM
#71
Man I wish these pictures were working, I've developed a leak from the front seal sometime in the past week and I'm going to tackle it in the next few days. It seems straightforward enough though, good thing the write up is so in depth.
96 4Runner Limited - 5100/99 Tall/906 Suspension, 265/75s on FJ80 wheels, 4xInnovations Sliders, Tepui Autana XL RTT
SOLD 99, 94 and 01 4Runners
10-14-2017, 06:43 PM
#72
Thanks
@ BigFishAllDay
Just noticed the leak last week. Took care of it today. Amazon'd a Toyota seal.
I should pick up a seal puller tool. After trying to improvise with a few different things I ended up going screw-in-the-seal face to pull it out.
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
04-05-2020, 03:46 PM
#73
Thanks BFAD for this! This came right up when researching my issue - I have this with my front output on my '98. I knew what I was in for when I saw your name on the how-to, which meant I immediately felt better since there was fantastic documentation!
Hope you and your family are well!
1998 T4R SR5 Natural White 4WD 5VZ-FE-V6-3.4L / ARB / Subaru-Hilux Gauge Pack / 199mm TBU / BFG All-Terrain KO2 265/70/R16
Build Thread. T4R & adventure photolog.
09-23-2020, 09:25 PM
#74
I got an oil change recently and noticed there was a slight leak in the transfer case.
Pic
My questions are:
1. Should I get the whole thing done per OPs 1st-3rd post?
Idk which one is front and rear lmao?
2. Does replacing these seals mess with the transmission at all?
I will go to the hi tech transmission shop my mechanic recommended me since he didn't wanna do this job and get a quote, I'm expecting this will be around $400-500, could be less if they agree I purchase the parts and they just charge for labor.
2001 Toyota 4Runner Limited. 231k miles.
09-25-2020, 10:53 PM
#75
Bump
