Old 03-23-2023, 01:54 PM #1
etc.'s Avatar
etc. etc. is offline
etc. is on a distinguished road
etc.'s Avatar
A/C signal circuit testing
Does anyone happen to have a couple screenshots of the A/C signal circuit testing procedure?
1996 4runner 3.4 4x4
1996 T4R Limited - stock
1997 T4R Limited - stock
2015 TEP w/KDSS - stock
etc. is offline   Reply With QuoteReply With Quote
Old 03-24-2023, 09:18 AM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
1996 ac ewd
Old 03-24-2023, 06:03 PM #3
etc.'s Avatar
etc.'s Avatar
Thank you.
I should have been more specific.
Using a 2000 4runner FSM while trying to diagnose DTC P0505, it says if you pass the idle test, to move on to step 6: Check A/C signal circuit (See page AC−91).
https://www.toyota-4runner.org/attac...ine-5vz-fe-pdf
Old 03-24-2023, 07:47 PM #4
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
you can jump the 2 pin AC pressure sensor connector under the hood on the AC line, if everything is working the AC clutch should engage, that should tell you if its a pressure issue and if the AC clutch is working correctly.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 03-24-2023, 08:08 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Using the wrong year fsm could be bad idea in certain instances.
As there are 3 different climate controls in this generation.
1996 is quite a bit different wiring then a 2000.
Old 03-25-2023, 07:19 PM #6
etc.'s Avatar
etc.'s Avatar
I understand that. Reason for the 2000 FSM is because it's what was available and is essentially what Timmy the Toyota Guy says in his video.
Old 03-25-2023, 07:34 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The reason is nobody wants to pay for them. Let's be honest. Nobody wants to pay for the paper versions or the techstream subscriptions.
Thus why folks are always looking for a an electronical wiring diagrams etc.
I actually got the tech scream subscription to down all the electronical diagrams for all the 3rd gen models.
So I can work on my fleet of 3rd gens. I release the EWD only to help people.
But I am done helping on this thread. Good luck.
4runner , a/c , circuit , signal , testing
Dome light Circuit Keppers12 4th Gen T4Rs 9 09-19-2022 07:43 AM
Bench testing a turn signal flasher. KidVermicious Classic T4Rs 7 11-26-2013 07:28 PM
inverter using add a circuit? matthewkristof Engines / Suspension / Wheels / Tires / Audio / Accessories 2 06-28-2013 08:24 PM
best circuit to use for a hour meter jlboers Maintenance/Detailing 13 03-05-2006 11:50 AM
