Old 03-07-2021, 03:49 PM #16
Blurm Blurm is offline
Blurm is on a distinguished road
Originally Posted by jmattioli View Post
Hey everybody, I wanted to get some clarification on testing my coil packs. I have a volt meter that reads ohms, but last night I tried to test the coil pack on the cylinder that is getting a misfire read (#5). I don't think I tested it correctly since I tested all 3 of them (including one that I had installed new 6 months ago) and they all came back as 001. I may not be touch the volt tips to the correct places.
Here is what I did. Please let me know where I messed up.
1. Disconnected negative battery cable
2. Removed air cleaner hose
3. disconnected high-tension cord
4. disconnected electrical connector
5. where the electrical connector plugs into the coil pack, i used the two prongs from the volt meter to get a reading.
Any help is much appreciated.
Thanks
This may sound like a stupid question but I just bought this 4runner 6 mos ago and I am not that familiar with how the engine operates. I am use to working with VWs that have coil packs for each cylinder where the 4runner has only 3 on cylinders 1-3-5.....My question then is can a bad coil cause misfiring on cylinders 2-4-6.
I am getting a recurring misfire on cylinder 2 where I have swapped plugs and replaced coil wires and the misfire remains. So can a bad coil pack on the other side cause this misfire since the plug wire connects adjacent to the coil pack. The reason I ask is bc the coil wire connects right next to the coil pack and it must connect to the ECU right there next to the coil pack.
Blurm is offline   Reply With QuoteReply With Quote
Old 03-08-2021, 12:32 PM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
A bad coil can cause a misfire on only 1 of the 2 cylinders it services. Try swapping ignition coil locations and see if the misfire follows. If it doesn't follow the ignition coil then it's time for a compression test.
3.4L Coil Pack Testing - Acceptable Ranges? GSGALLANT 3rd gen T4Rs 1 11-29-2017 05:08 PM
Please HELP!!!... SPARK PLUG/COIL PACK PROBLEM Ashlyn Classic T4Rs 0 10-23-2010 02:23 AM
FS: Ignition Coil Pack Third Gen paperthin Classifieds - buy & sell (no commercial ads please) 1 01-25-2010 05:11 PM
Question about coil pack Brutus 3rd gen T4Rs 3 01-05-2010 01:52 PM
Bad Coil Pack??? ihrunner Maintenance/Detailing 6 07-29-2008 05:28 PM
