11-17-2011, 05:00 PM
Real Name: Matt
Real Name: Matt
07 Fj powdercoated rims...need opinions
So I've seen a few of you rocking the Fj rims on their 3rd gens and I like the look. I've been wanting some black shoes for my rig for some time now, but wasn't sure which route to go. An opportunity arose to pick these up for a great deal, so I took a chance. I had a local powder coat company apply what they called "hammered black" to the rims. I was apprehensive on dropping $65 per rim without seeing a sample of the final product, but once I got them back, I'm very happy with them.
This is where I need your help/opinions...you can't pc the center caps, and I have been told you can't replicate the pc's 'hammered finish' from a quality rattle can. I typically don't like a two toned rim, but this doesn't look too bad. Do I go cap-less? two toned? or do you have any other ideas?
(without)
(with)
2006 Nautical Blue V8 AWD - King resi CO's & 2.5" rears, Icon 2" Spring
Builtright UCA, Magflow 50 series (resonator delete), Morimoto D2S 4.0's...etc
Sold- 2002 Thundercloud Grey, Sport Edition- King Coilover's, Builtright UCA
11-17-2011, 05:19 PM
you may have some luck with plastidip for the paint but wheels take some major abuse so paint is most likely going take a lot of maintenance
I would order up some of these or find them on eBay. I've seen people use them for those wheels.
your wheels look good BTW. but yeah i think i got all 4 for around $50 but of course they didn't fit my pro-comps so i sold them a while back
01 SR5 SPORT
Many mods done, Many more to come
Build Thread
http://www.toyota-4runner.org/3rd-ge...ld-thread.html
11-17-2011, 05:31 PM
Real Name: Matt
Real Name: Matt
I thought the same for those caps. My mechanic has some on display and I tried them out, but they don't fit properly. IIRC, those were designed for the TRD rims, not the alloys.
I considered plasti, but I think with the plasti on top of pc will look like spinners on a Bentley...
11-17-2011, 05:33 PM
Real Name: Matt
Real Name: Matt
Frankly, I think they look pretty smooth with the silver/black look above.
2020 Tundra SR5 CrewMax 4WD, Voodoo Blue, SR5 Upgrade/TRD OffRoad Packages.
Retired: 2000 4Runner SR5 Highlander 4x4.
11-17-2011, 07:37 PM
Real Name: Evan
Real Name: Evan
If I were you I'd Plasti Dip them, then find a "Hammered" finish spray paint to see how close it matches. If you don't like it, you can peel it off and figure something else out.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
11-17-2011, 07:46 PM
With a little modification, they'll fit...
2001 T4R SR5 4WD
11-17-2011, 08:40 PM
Dupli-Color :: Truck Bed Coating
I use the aerosol version of that for a similar texture/look on some parts. Just make sure you use light coats from a distance, if you go heavy it won't have the texture you want.
11-17-2011, 08:43 PM
Real Name: Justin
Real Name: Justin
+1 for the TRD center caps
Check out my Instagram! @808_hiker
1998 4Runner Limited Desert Dune 3.4 V6 Auto 4x4 ToyTec Ultimate/Superflex 3” Lift ~83k miles
2008 Tacoma Regular Cab Desert Sand 2.7 4banger 5MT 4x4 Bilstein 5100/AAL/Block 3” lift ~101k miles
2010 Tacoma Access Cab Black Sand Pearl 4.0 V6 Auto 4x4 TRD Off Road ToyTec Ultimate/Dakar 3” lift ~22k miles
2018 Tacoma DCSB Quicksand 3.5 V6 6MT 4x4 TRD Sport ToyTec Boss/Dakar HD 3” lift ~6k miles
11-17-2011, 09:58 PM
Real Name: Allen
Real Name: Allen
I like the 2 tone.
2003 Toyota 4Runner SR5 iForce 4.7L V8 2WD Natural White With Plastic Bumper Cladding, Everything Completely Stock.
Owned since 10/3/11
90,000 Miles and counting!
11-18-2011, 12:51 AM
Care to explain?
'04 GGM 4Runner SE-V8 4x4/XREAS/Auto Dim-Compass rear view/homelink/RSCA curtain system/Pioneer deh-x8500bs/Grabber AT2/Gibson CBE/HCF Delete/Gobi Ladder/yellow HID Fogs.. awdjunkies build thread
Shout out to Stuck_CAPS For this GEM: http://www.toyota-4runner.org/4th-ge...iy-videos.html
11-18-2011, 09:25 AM
No more plasti dip fer gawd sake…. Keep the two tone. Remember to put the white letters IN.
11-18-2011, 10:39 AM
You could match your body paint...thundercloud grey wouldn't look bad to me.
戦争イーグル
Cory J
Wheel converter,
11-18-2011, 11:35 AM
My vote is for the two tone.
A Giant work in progress.
11-20-2011, 02:52 AM
2001 T4R SR5 4WD
11-20-2011, 10:25 AM
Plasti dip has it's uses and if the OP isn't sure which color scheme he likes then it's a great way to test different colors out since it's so easily taken off.
I agree though...white letters definitely in.
戦争イーグル
Cory J
Wheel converter,
